FTP archive doesn't work for telnet only switch
Jeremy Dubrulle
I'm configuring archive with write-memory and ftp path on several switches.
It's working for almost all of them, I have my conf on my server.
The only 3 switches where it doesn't work are switches where ssh isn't available. I mean it's not even in the IOS.
That seems weird but that's the only thing that is different from the other switches.
Do you know why is it happening ?
When I do a show archive, it's like it's working ! But nothing on the server. Nothing in show logging.
My conf:
ip ftp username configbackup
ip ftp password 7 XXXXXXXXXXXXXXXXXX
archive
path ftp://X.X.X.X/mypath/$h-$t
write
balaji.bandi
here is for reference : (make sure on the destination you have write access and file exists to write)
https://www.ciscozine.com/how-to-use-archive-command-to-save-configuration/
BB
Jaderson Pessoa
Hello @Jeremy Dubrulle ,
try it under archive configuration
path ftp://user:password@server/folder/$h_
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hello
archive
write
Example:
ip ftp password xxxxxxxxxx
ip ftp password passive
ip ftp source-interface  xxxxxxxxxx
exception core-file FTPdump compress
exception protocol ftp
exception dump <path X.X.X.X>
Kind Regards
Paul
Thanks for all the replies but it seems like I was not clear because my commands are working for 90% of my switches.
I'm doing a path ftp... and write under archive mode. That's only for the telnet-only switches that the file isn't copied under the server.
However I'll check the commands you gave me Paul. Thanks
