FTP on our network
londint
I need to be able to find out any source on our network that has FTP running, either on the routers, servers or workstation.s
Is there any software I can use to give me this information?
andrew.burns
Level 7
Level 7
The easiest way would be to do a port scan on tcp/21 using something like nmap:
http://www.insecure.org/nmap/download.html
(this assumes that ftp is only running on tcp/21, of course...)
Andrew.
desai.jaideep
Level 5
Level 5
I would recommend GFI Network Security Scanner available at:
http://www.gfi.com/downloads/downloads.aspx?pid=lanss&lid=en
JD
yjdabear
I think analyzing NetFlow exports can also help tracking down FTP traffic, especially if the FTP server only comes on intermittently.
