GLC-T 1000BASE-T SFP detected but unable to turn on
moman62
my router picks both up but I cannot configure them. when I do a no shut, nothing happens.
@moman62
checking the compatibility matrix for 4331, it seems it is not supported anymore.
 https://tmgmatrix.cisco.com/?si=4331
7 Replies 7
@moman62
which router is it?
cisco 4331 router the g0/0/2 ports
@moman62
ok, I discovered that one of the g0/0/2 ports is defective and that both SFPs do work. So even though they are EOL its still all good.
Leo Laohoo
Post the complete output to the command "sh license summary".
Port 0 & 1 are enabled by default.
Ports 2 & 3 are disabled until license is applied -- This information should be visible during bootup.
since when does an SFP need a license? all of my ports G0(mgmt) G0/0/0 & G0/0/1 are good? only port G0/0/2 where I plugged in the SFP's lights up is detected but when I plug in the ethernet cables, put ip addresses on them and do a no shut, they still show as down.
Here are the results from my show inventory:
NAME: "subslot 0/0 transceiver 0", DESCR: "GE T"
PID: ABCU-5710RZ-CS4B , VID: 2 , SN: AGM1524215M
NAME: "subslot 0/0 transceiver 2", DESCR: "GE T"
PID: ABCU-5710RZ-CS4 , VID: B2 , SN: AGM182528CK
