GUI interface on WLC
NetworkingNewbies
Community Member
I am trying to connect to GUI interface of WLC but it is continuously showing "Server Reset Connection". I configured the management interface of WLC with an IP 192.168.10.10 and PC connecting with the WLC with an IP 192.168.10.11. The PC and WLC are able to ping each other. I am using Packet Tracer version 9.0.0.0810.
I have done the same thing few years back.
Wireless LAN Controller WLC - Configure a Basic WLAN using WPA2 PSK using GUI in Packet Tracer
Any help.
Thank you.
Ben Weber
Hey @NetworkingNewbies
The WLC GUI in Packet Tracer is known to be a little buggy, I think it is an issue with how the software handles HTTP requests & sessions. If you haven't already, I would try accessing the GUI over both http://192.168.10.10 and https://192.168.10.10
See: WLC Setup Issue: Server Reset Connection - Cisco Community
Good luck!
- BW
Please rate posts if they have been helpful.
