Help Creating Syslog Message that Uses Router Hostname
Paul Wishart
We currently have an IP SLA tied to EEM scripts which work great for sending syslog messages for alerting purposes.  However, I'd like for each router that sends a syslog to send its hostname using wildcards instead of the hostname specified.  I am guessing some kind of pattern matching would do the trick, but I can't find any good documentation on it.  This is what I currently have:
ip sla 1
icmp-echo 172.24.50.1 source-interface GigabitEthernet2
threshold 250
timeout 1000
frequency 5
ip sla schedule 1 life forever start-time now
event manager applet LAN_interface_Link_down
event syslog pattern "Interface GigabitEthernet2, changed state to down"
action 1 cli command "enable"
action 2 syslog priority informational msg " command LAN_interface_Link_down is running on C1-GrandView-PA-CSR1000-Recover ..."
action 3 wait 5
action 4 cli command "configure terminal"
action 5 cli command "interface range t3 -4"
action 6 cli command "shut"
action 7 cli command "end"
event manager applet LAN_interface_Link_up
event syslog pattern "Interface GigabitEthernet2, changed state to up"
action 2 cli command "configure terminal"
action 3 cli command "interface range t3 -4"
action 4 cli command "no shut"
action 5 cli command "end"
action 6 wait 15
action 7 syslog priority informational msg " command LAN_interface_Link_up is running on C1-GrandView-PA-CSR1000-Recover ..."
event manager applet Next_Hop_LAN_Unreachable
event track 10 state down maxrun 40
action 2 syslog priority informational msg " command Next_Hop_LAN_Unreachable is running on C1-GrandView-PA-CSR1000-Recover ..."
action 3 wait 5
event manager applet Next_Hop_LAN_Reachable
event track 10 state up maxrun 40
action 6 wait 15
action 7 syslog priority informational msg " command Next_Hop_LAN_Reachable is running on C1-GrandView-PA-CSR1000-Recover ..."
Joe Clarke
You can use the info action to gather the hostname:
action 1.0 info type routername
action 2.0 syslog msg "My name is $_info_routername"
Joe Clarke
Joe, thanks so much for your reply.  I will try this and get back to you.
Hell yeah!  It worked!  Thanks Joe!
