Help understanding Eth Mgmt Interface
Brad Boudreau
Visitor
I am trying to configure the management interface on the back of a Cisco 4331 router and am having a hard time wrapping my head around getting it to work.  I read through the 6 page Cisco doc "Configuring ethernet management port" and it seems really straight forward.  My issue is that I can't seem to get access via putty.
My physical connectivity is as follows:
4331 Mgmt port -> Switch -> Mgmt laptop
My router config has the follow for the Mgmt port:
Switch# configure terminal
Switch(config)# interface gigabitethernet 0
Switch(config-if)# vrf forwarding Mgmt-vrf
Switch(config-if)#ip address 192.168.45.2 255.255.255.0
Switch(config-if)# end
If I try to ping 192.168.45.2 from the router via serial cable putty session it fails (which I gather is expected) and when I use the command "ping vrf Mgmt-vrf 192.168.45.2" the pings are successful.
When I go over to my Mgmt laptop (192.168.45.20/24) connected to the switch I can't ping 192.168.45.2 nor can I connect to it via telnet/ssh in putty.
I did see some docs stating that you need an ip route added to the Mgmt-vrf using the next hop, but there is no next hop since I am not planning on routing management.  As a hail mary I added the route which didn't do anything.
I can also confirm that I did set up ssh properly as if I try to ssh to a routing interface I can get in with putty as expected.
If anyone can let me know what I am doing wrong I would really appreciate it.
Thanks!
the mgmt have separate than data RIB
so connect your PC to mgmt interface and you can access.
Thank you for the quick response.
Do you mean I have to directly connect a PC to that port and I am "breaking" it if I put a switch in the middle?
leovince
Community Member
Thanks!
I got this,...
Thank you,..
