HELP Using EEM
jaydiemoore
Community Member
Im trying to use EEM to check the output of "show interface description | include TEST" to shutdown all ports with the description TEST. Was wondering if anyone had any ideas
Jason Pfeifer
Here is a .tcl EEM policy which should help.  It does some extra checking to narrow by interface type.  You can
remove that if needed.
Thanks.
::cisco::eem::event_register_none maxrun 120 default 120
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
# 1. execute cli commands to gather data
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
if [catch {cli_exec $cli1(fd) "enable"} result] {
if [catch {cli_exec $cli1(fd) "show int desc | in TEST"} cli_show_int] {
    error $cli_show_int $errorInfo
foreach line [split $cli_show_int \n] {
    set match1 [regexp {^[F|G|T][a|i|e][0-9|/]+} $line match]
    if {$match1 == 1} {
        if [catch {cli_exec $cli1(fd) "conf t"} result] {
        if [catch {cli_exec $cli1(fd) "interface $match"} result] {
        if [catch {cli_exec $cli1(fd) "shutdown"} result] {
        if [catch {cli_exec $cli1(fd) "end"} result] {
        puts "shutting interface $match"
    } else {
        puts "skipping interface $line"
Here is a sample EEM applet which does this as well:
event manager applet desctest
event none
action 100 cli command "enable"
action 101 cli command "show int descr | inc TEST"
action 102 foreach line "$_cli_result" "\n"
action 103 regexp "([^\s]*).*TEST.*" $line match _int
action 104 puts "line is --$line--"
action 105  if $_regexp_result eq "0"
action 106   puts "Interface is $_int"
action 107   cli command "conf t"
action 108   cli command "interface $_int"
action 109   cli command "shutdown"
action 110  end
action 111 end
