help using snmp to set trunk port
barry.ard
I need some assistance in locating the mib/variables to allow me to set a trunk port and add/remove vlans on that interface. The equivalent of:
switchport mode trunk
switchport trunk allowed vlan 400,401
This is on a 4506 running IOS 12.2.25 but will later include other IOS based switches. I could use setHostConfig and but would like to avoid that if possible.
Barry
ToddWarren
Not sure if this will give you all you need, but.....the closest I could find are:
CISCO-L2L3-interface-config-mib
CICSO-VTP-MIB
Hopefully, these 2 MIB's can maybe lead you in the right direction. Go here to view these:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2
Hi Todd,
I had looked at the CISCO-VTP-MIB and my first thoughts was that it was just informational but after closer inspection I think it will do what I want but not without a lot of pain.
Thanks for your input.
Barry.
"There is no joy, if there is no pain." author unknown, but probably a Cisco Sales Engineer :o).
rolf.fischer_2
Barry,
I really would not recommend to do so.
First you need to know which interface-index is associated to the interface. That's not a big thing but it has to be done first.
Then you need to change several OIDs in the CISCO-VTP-MIB, like vlanTrunkPortDynamicStatus (1.3.6.1.4.1.9.9.46.1.6.1.1.14.Index). (This one is read-only access so you can't set it, it's just an example for trunk related OIDs)
A VERY good source for OIDs is http://www.mibdepot.com, use the search function.
(Try keyword: TrunkPortDynamicStatus to get an idea)
But, like mentioned before, you need to change several OIDs and you really need to know what you're doing.
I personally read (GET, GETNEXT) information like that from my devices but I wouldn't set them.
And: Different plattform - different OIDs.
Hope, that helped at least a little bit.
Rolf
