Hiding SCP Password Using Archive Feature
Richard Clayton
Hi Guys
What I'm trying to achieve:
1.  Every time an engineer runs the write-memory command, a copy of the running config is sent to my SCP server.
2.  Every 7 days, a copy of the running config is sent to my SCP server.
3. The password in configuration is not shown in clear text.
It's just #3 that I hope there is a fix for.
Here is an example of my config.
archive
 path scp://user:password@1.2.3.4/CUSTOMERS/CUSTOMER1/CUSTOMER-LONDON6-ETH1.cfg
 write-memory
 time-period 10080
Because the password part of the SCP config is not an IOS recognised password I don't appear to be able to encrypt it.  If that's the case is there a secure fudge, like somehow referencing a local username that does have password encryption.
I'm not looking for server based solutions like SolarWinds etc.
Rick
9 Replies 9
 I dont think there is a way around it. What I suggest is not send the backup to the external server right the way but store it in the flash. Then, from the remote server you stract using SCP. The cisco device will act as scp server and not client.
Thanks for responding but I'm looking for a secure push to server solution instead of a pull from server.
Service password encryption <<- I think this command effect your scp config copy.
This isn't correct.
Rick
Leo Laohoo
archive
 log config
  HIDEKEYS
This isn't correct, this command hides IOS aware passwords in the saved config.
Rick
kirchhoffpolska
HI
I am facing exactly same issue with SFTP
Did you found solution for that?
Pawel
Martin Blaesser
Hi, password encryption ist not possible.
But Schedule and with "write" are :
archive
log config
logging enable
hidekeys
path scp://user:pass@w.x.y.z/$h_
write-memory
kron occurrence save-config-schedule at 22:00 recurring
policy-list save-config
kron policy-list save-config
cli archive config
Josue Ruiz
Is there any update on whether credentials can be hidden?
