How many seed devices can be entered into the ANI Discovery settings?
getwithrob
Level 3
Level 3
When seed devices are added via the GUI, the ANIServer.properties file is modified by the application. Each time a seed is added, it appends to the same line. I've added so many that the line is too long when looking at it in VI and probably by the application. Does anybody know the max number of entries in Ip address format (xx.xx.xx.xx) that can be entered?
rmushtaq
Level 8
Level 8
There isn't any set limit
mbilgrav
Level 3
Level 3
I run 180+ seed device, all inserted via ANIServer.properties file.
But you can also add/edit them with the GUI
Thanks for the response. I'm glad to hear it's working for you. I heard of another user who's putting over 800 in by editing the file. I'm going to attempt this on Thursday....
