How to Calculate bandwidth using SNMP index
Dinesh Murthy
Kindly explain how to calculate interface traffic utilization using ifInoctets and ifOutOctets.
what is the formula that monitoring tools are using to calculating the traffic ? I searched a lot but each one telling different things i totally confused a lot with this. Please provide solution for this.
Dinesh Murthy
5 Replies 5
AFROJ AHMAD
Hi Dinesh,
check the below link::
http://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/26007-faq-snmpcounter.html
hope it answer your query.
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi AHMAD,
 Thanks a lot for your reply. I need the exact formula to calculate it. I used the formula which is provided in cisco. If i need total utilization whether i have to add all the values.
Input Bandwidth
(∆ifInOctets * 8) /No. of seconds in ∆
Ouput Bandwidth
(∆ifOutOctets * 8) / No. of seconds in ∆
Utilization
(Bandwidth/ifSpeed) *100
Throughput
(∆ifOutOctets - ∆ifOutDiscards)*8/No.of seconds in ∆
Dinesh Murthy
Hi ,
this has the exact answer of your query::
http://www.cisco.com/c/en/us/support/docs/ip/simple-network-management-protocol-snmp/8141-calculate-bandwidth-snmp.html
Note** mark this thread as resolved , if it was helpful
Thanks-
Afroz
I already worked with this cisco formula and i got some values something like bits/s. If i need to calculate 1 hour traffic, then i need the add sum of bits/s for 60 mins right ?
Dinesh Murthy
yeah, that's should work
