How to enable status on WS-C2960X-24TS-L USB port
EJ Talamayan1
Good day!
As per checking usb port in our 2960-x network switch is disabled, Is there a specifc command to enable it? Thanks!
OOB_SWITCH#show usb port
Port Number: 0
Status: Disabled
Connection State: Disconnected
Speed: Full
Power State: ON
Port Number: 1
Status: Disabled
Speed: Full
Power State: ON
Leo Laohoo
IF you insert a USB thumb drive, what shows up in the logs?
balaji.bandi
as suggested there is no command to enable, the ports are active, make sure you use right USB and connect, you see Logs what is USB number.
BB
Deepak Kumar
I agree with balaji there is no command. What is size of USB disk, what's format of disk? Are you getting anything in logs?
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
