How to license LMS?
jmorrison_phn
The license URL doesn't work anymore, and searching the site doesn't return anything useful about licensing LMS.
http://www.cisco.com/go/license
Has licensing changed? I don't have a PAK only a s/n now.
yjdabear
http://www.cisco.com/go/license is redirecting to https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet fine for me. But since you don't have a PAK, you may need to email licensing@cisco.com for further assistance.
yjdabear
Joe Clarke
It appears Cisco.com was having problems.  None of the "go" links were working.  They are now back.  You should be able to access http://www.cisco.com/go/license .  However, you will need a PAK which should have arrived with the LMS DVD.
Well at least it's now showing a proxy error instead of page not found.
No PAK, just a S/N number because of the account. Maybe they're wrong.
Update: S/N = PAK
