How to login remote access to network Devices?
azahmed887
Hello Engineers
i am little bit confused of what is the IP address that i can remote access to it via SSH or Telnet in switch or Router is it (Interface VLAN) or even the (IP of physical interface)? And must be with same network pc to access remote switch or router or even different subnet can connect to remoted network devices?
i am studying CCNA so that the question thinking about it
You can access sw or router via
Loopback IP
Interface IP
SVI IP of any vlan
The must important is the reachable between your pc and IP you want to access.
MHM
5 Replies 5
Loopback IP
Interface IP
SVI IP of any vlan
MHM
thanks for answer
that really helps me MHM
I am having the same issue. I can access my switches via the IP on the vlan of the subnet I am currently on. I can ping the IPs of the other vlans and I can ping the loopback ip but I can't ssh or access the gui on those IPs. Just the IP on the subnet my system is on. If I go to a system on a different subnet I have the same issue.
Do you have a default gateway set on the switches?
Yes it isn't a gateway issue. I can access most devices across the network. It is just the interfaces on the switches that is giving me an issue.
