hsrp configurations for inter-vlan
212162s
hii i need help with hsrp configurations tho ive got the basics alr
as seen in the above image, I've shut down the main interface g0/0/1 for r2. however, both routers have standby 'unknown'.
^ r3 router
^ r2 router
each sub-interfaces have their own virtual router.
From beginning there was no active/standby
Issue is the SW bridge two hsrp routers.
I see there two link between SW's' remove one link
Save config
Close lab
Open again
Then check hsrp
MHM
M02@rt37
Hello @212162s
Between Switches, ensure to have one link and all vlan tagued. Trunk port with vlan id 10,20,30,40,50 and 60.
Best regards
