How to reload / reset IOS device via snmp
sthon-dbsys
I only found an info about CatOS devices:
http://www.cisco.com/en/US/customer/tech/tk648/tk362/technologies_q_and_a_item09186a00800b69af.shtml
anyone has an idea how the reset an IOS device with snmpset
thx
8 Replies 8
it does not work wirth 3750 and IOS 12.2(25)SE.
I also found an info about the sysReset object at:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=sysReset
but the mib of 3750 and IOS 12.2(25)SE does not include the sysReset Object.
oper@ffm002nvz:/lanbf/home/oper/sthon/bin>snmpwalk -c read router .1.3.6.1.4.1.9.5.1.1
cisco.workgroup.ciscoStackMIB.systemGrp.sysTraffic.0 : INTEGER: 0
cisco.workgroup.ciscoStackMIB.systemGrp.sysTrafficPeak.0 : INTEGER: 0
cisco.workgroup.ciscoStackMIB.systemGrp.sysTrafficPeakTime.0 : Timeticks: (146335508) 16 days, 22:29:15.08
cisco.workgroup.ciscoStackMIB.systemGrp.sysEnableChassisTraps.0 : INTEGER: disabled
cisco.workgroup.ciscoStackMIB.systemGrp.sysEnableModuleTraps.0 : INTEGER: disabled
cisco.workgroup.ciscoStackMIB.systemGrp.sysTrafficMeterTable.sysTrafficMeterEntry.sysTrafficMeterType.1 : INTEGER: systemSwitchingBus
cisco.workgroup.ciscoStackMIB.systemGrp.sysTrafficMeterTable.sysTrafficMeterEntry.sysTrafficMeter.1 : INTEGER: 0
cisco.workgroup.ciscoStackMIB.systemGrp.sysTrafficMeterTable.sysTrafficMeterEntry.sysTrafficMeterPeak.1 : INTEGER: 0
cisco.workgroup.ciscoStackMIB.systemGrp.sysTrafficMeterTable.sysTrafficMeterEntry.sysTrafficMeterPeakTime.1 : Timeticks: (146335508) 16 days, 22:29:15.08
cisco.workgroup.ciscoStackMIB.systemGrp.sysStandbyPortEnable.0 : INTEGER: enabled
cisco.workgroup.ciscoStackMIB.systemGrp.67.0 : INTEGER: 2
very strange
Have you got the latest CISCO-STACK-MIB installed?
I ever thought that the mib is implemented in the IOS.
Do I have to install it manually on the switch ???
Sorry I meant on the latform that you are running snmpwalk on.
I just tried to reload a cat3750 running 12.2(25)SEB2 as documented in: http://www.cisco.com/en/US/tech/tk648/tk362/technologies_q_and_a_item09186a00800c263d.shtml#qa4
It worked once I put the snmp-server system-shutdown in the config.
Here are the steps I performed:
> snmpwalk -c public 14.32.100.13 sysDescr
SNMPv2-MIB::sysDescr.0 = STRING: Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(25)SEB2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 08-Jun-05 04:49 by yenanh
> snmpset -v 1 -c private 14.32.100.13 tsMsgSend.0 i 2
Error in packet.
Reason: (badValue) The value given has the wrong type or length.
Failed object: OLD-CISCO-TS-MIB::tsMsgSend.0
> telnet 14.32.100.13
Trying 14.32.100.13...
Connected to 14.32.100.13
Escape character is '^]'.
User Access Verification
Password:
nms-3750>en
Password:
nms-3750#conf t
Enter configuration commands, one per line. End with CNTL/Z.
nms-3750(config)#snmp-server syst
nms-3750(config)#snmp-server system-shutdown
nms-3750(config)#exit
nms-3750#wr mem
Building configuration...
[OK]
nms-3750#exit
Connection closed by foreign host.
OLD-CISCO-TS-MIB::tsMsgSend.0 = INTEGER: reload(2)
thx a lot, the missing "snmp-server system-shutdown" was the reason I got in Problems.
with configured "snmp-server system-shutdown" all works fine.
thx a lot
I am glad to hear it.
