09-05-2022 11:43 PM
How i can remove switch ports from up down status alert as well as from interface utilization TX and RX in Cisco Prime. I want only the WAN links to show up with this detail.
Solved! Go to Solution.
09-06-2022 02:30 AM
If you do not like to send alerts for the normal interface, you can configure on switchport
no logging event link-status
no snmp trap link-status
On prime you can also supress :
Monitor / Monitoring Tools / Monitoring Policies
09-06-2022 02:30 AM
