How to select part of a string?
rychaney
I have the following string from a cli command output:
630860 packets input, 624821204 bytes, 0 no buffer
I want to select the number of bytes which is of a variable length. Is there a way to do this with the action string commands? I couldn't get this to work for me.
Kind regards,
Ryan
Joe Clarke
Use regexp:
regexp "([0-9]+) bytes" $string match bytes
puts "Bytes is $bytes"
Joe Clarke
Use regexp:
Ok this works.
What do the ( ) brackets indicate? I had tried a similar string in the past but I didn't have these brackets.
Ryan
They indicate that you want to extract a sub-match, in this case the number of bytes.
