How to use SFTP to upgrade WS-C2960X-48TS-LL
HCL Support
Our client  want to upgrade IOS of WS-C2960X-48TS-LL by SFTP.
Can we upgrade?
If yes then please share steps will be performed..
#sh ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.0(2a)EX5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Mon 16-Feb-15 08:16 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(2r)E1, RELEASE SOFTWARE (fc1)
uptime is 15 weeks, 5 days, 4 hours, 27 minutes
System restarted at 10:12:40 IST Sun Jan 21 2018
System image file is "flash:/c2960x-universalk9-mz.150-2a.EX5/c2960x-universalk9-mz.150-2a.EX5.bin"
Diana Karolina Rojas
Hello!
I thing you can not do the upgrade this way, that device only supports FTP, TFTP and RCP for copy files, you can probe that using "copy ?" command, and also you can review this link https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/file_management/file_management/img_files.html
Please do not forget to rate or mark useful post.---
Thanks a lot for reply..
