how to use sh script to ssh login sup720
julxu
we configured our sup720 to use ssh only. no telnet.
that bring me a problem to write shell script to access sup720. the pseudo terminal not work anymore.
Cold I get advice how the shell script can implement ssh login to access the box
Any comments will be appreciated
Thanks in advance
paddyxdoyle
Level 6
Level 6
What client are you running the script from.
If it's a windows client you could download and install putty which is a freeware SSH client. If you add the directory where putty resides to your PATH variable you can invoke SSH from the command line.
If is a Unix client then i believe you will be able to SSH from the command line already as support for SSH has been around for a while, certainly on Solaris and Linux.
PD
