i need help
aarne.pallari
Hi  need litel bit of help im trying to get hold off Asdm For Asa 5510 v7  but no luck so is ther eny one hear who can help me
Aarne
Is it a lab or production environment?
 Are trying to install asdm on ASA and are you receiving any erros?
Did you  transfer the image to the asa already?
carstenlymann1
also, can you access the ASA with SSH ??
Please remember to select a correct answer and rate helpful posts
/ Carsten
