Icmp Jitter collector configuration with Cisco LMS
aryarahul
I am trying to collect jitter information of cisco Routers which are added in Cisco LMS
I have configured collector icmp jitter for them but somehow no stats are visible in lms and its says in IPM that u have no jitter collectors configured.
Do i need to enable anything on the Router as well to export stats to LMS ?
19 Replies 19
LMS 3.1 is very old.
I would suggest you to upgarde the LMS to 3.2.1 as there were few known issue in LMS 3.1
Thanks-
Afroz
***Ratings Encourages Contributors **
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
So ICMP Jitter Collectors wont work with 3.1 ?
HI ,
You are running a version which already end of support.
Atleast  upgarde it to 3.2.1 and which was most stable version of LMS with a lot of enhancment with respect to IPM
in the meantime check the below output and see if you are able to see the result of the operations in it:
show ip sla statistics
Thanks-
Afroz
One quick thing :
you are using SNMP v2 or SNMPv3 on your devices ?
***IMP >> you need to have  SNMP RW credentials added in LMS for IPSLA to work for any device.
Thanks-
Afroz
aryarahul
I am using snmp V2 with both RW and WR credentials , still not working though
