ICMP Timestamp Request Remote Data Disclosure on Catalyst 9300
Jeff Horton
Level 3
Level 3
From an ACAS scan, I am getting the "ICMP Timestamp Request Remote Data Disclosure" (Tenable 10114) from one of my Catalyst 9300 switches. I am currently on IOS XE version 17.13.1. I have five other catalyst 9300s that are not showing this issue. Any idea why one would and other would not? I have compared the configurations on multiple switches with the one that is having this issue and they are all the same.
7 Replies 7
balaji.bandi
First i would check the configuraiton between those 2 devices.
One of the suggestion to add ACL :
access-list 10 deny icmp any any timestamp-request
access-list 10 deny icmp any any timestamp-reply
access-list 10 permit ip any any
int gig x/x
ip access-group 10 in
BB
Mark Elsen
 - Verify ACL solution offered  from @balaji.bandi with for instance :
               #  hping3 switch-ip-address   --icmp --icmp-ts -V
  And look into latest advisory software version , if applicable and try again with the above command ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Jeff Horton
Level 3
Level 3
I don't have that configuration on any of my other switches and they are not reporting this issue. All of them are running the same version (17.13.1).
if you compare the time on all switches, is it exactly the same ? Which version of the plugin are you using (version 1.53 being the latest I believe) ?
https://www.tenable.com/plugins/nessus/10114?_gl=1*by96ki*_ga*ODczMDk0Mjc3LjE3MTUyMDMwOTQ.*_ga_HSJ1XWV6ND*MTcxNTIwMzA5My4xLjEuMTcxNTIwMzcxNC42MC4xLjE3NDk0MTM4MjY.
Jeff Horton
Level 3
Level 3
I have no idea what version of plugin is being used as I don't do the scans.
I applied this version of ACL on my switch and applied it to my interface vlan that has the switch ip address. Waiting for CS team to rescan:
ip access-list extended 100
    permit ip any any
int vlan x
ip access-group 100 in
keep us how it goes when you have feedback from pen testing team.
BB
Mike H5
Did that ACL work? I have the same thing going on with our security scanner. I added this access list:
ip access-list ICMP_Timestamp
20 deny icmp any any timestamp-request
30 permit ip any any
Then applied it:
interface GigabitEthernet0
ip access-group ICMP_Timestamp in
This resulted in ALL pings matching the timestamp-reply line and being dropped.
It only allows pings when i add:
5 permit icmp any any echo
Which I have a feeling will allow the timestamp lines as well. Its a ISR4431, this seems like odd behavior to me.
