LMS 4.1 https/syslog
redouanebali
Community Member
I have some problems with LMS 4.1. When i switch to https i can't accces
I have these message :
Forbidden
You don't have permission to access /cwhp/LiaisonServlet on this server.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
2 question : the timer of sysolg is not synchronised with the ntp server : when i see the error ( time it's ok) but when i see the same error in the syslog i have a one hour time lag.
Red1
8 Replies 8
v.nikolaev
Visitor
Hi.
I have the same problem. Any ideas?
There is sometimes a problem with the redirecting after you log in. Try to go direcly to this url:
https:///cwportal/group/lms/lms-monitoring
Cheers,
Michel
Hi Michel,
Your answer is about https or syslog??
Thank you
Red1
Here is recommendation from Cisco TAC. It was perect for me (Cisco Prime LMS for Windows 4.1. Problem: no access to portal after switching to https)
-- Dont forget to start you shell session as Administrator
net stop crmdmgtd
-- Remove server.*  files under NMSROOT\MDC\Apache\conf\ssl
NMSROOT\bin\perl NMSROOT\MDC\Apache\ConfigSSL.pl -disable
NMSROOT\bin\perl NMSROOT\MDC\Apache\ConfigSSL.pl -enable
-- If the command says something as " Usage ConfigSSL.pl -enable | -disable"
-- Please then try it like this:
--  NMSROOT\bin\perl NMSROOT\MDC\Apache\perl ConfigSSL.pl -disable
--  NMSROOT\bin\perl NMSROOT\MDC\Apache\perl ConfigSSL.pl -enable
NMSROOT\bin\perl NMSROOT\MDC\Apache\bin\ConfigSSL.pl -disable (only if you do not use SSL https://...)
net start crmdmgtd
-- Ensure that the following files are created under
--   NMSROOT\MDC\Apache\conf\ssl
--   server.crt
--   server.key
--   server.pk8
-- Wait about 15 minutes or so and login again.
Thank you very much Vladimir,
I will tray it.
Cdlt
Red1
I had a little trouble following Vladimir's response, so I paid attention while the TAC engineer did his thing...
Delete the server.* files as indicated in vlad's post above
at CMD prompt opened as Administrator:
C:\>net stop crmdmgtd
Then
C:\Program Files (x86)\CSCOpx\MDC\Apache>C:\Progra~2\CSCOpx\bin\perl.exe ConfigSSL.pl -disable
(after hitting enter, message was "SSL is disabled.  Restart Daemon Manager to reflect the changes.
Next command was
C:\Program Files (x86)\CSCOpx\MDC\Apache>C:\Progra~2\CSCOpx\bin\perl.exe ConfigSSL.pl -enable
Output was:
You don't have a private key and/or certificate
*** Running key and certificate generation utility ***
Please enter the following information.  It is needed to generate your temporary certificate
Country (2 letter code) :
State or Province (full name):
Locality (eg, city) :
Orgaization (eg, company):
Organization_unit (eg, company):
Host Name (eg, FQDN):
enter email address (eg, [email protected]😞
After hitting enter, the private key and certificate was generated.
net start crmdmgtd
IMPORTANT:  It took a good 15 minutes for the services to restart (as Vlad indicates).  You can check their status by typing
c:\Program Files (x86)\CSCOpx\bin>pdshow -brief
The TAC engineer said this was how they used to change the https/http login method on previous versions, but now there was a radio button on the Settings page in LMS.  Selecting that button is supposed to do what these command lines just did, but they are not.  BUG.
That works perfectly for me as well....
Thanks for that Post.
It also solved my Problem
