Impossible to upgrade IOS Catalyst 3560?
torleif
Hello!
I want to upgrade a Catalyst 3560-48PS to the last IOS.
I get an errormessage stating that there is insufficient space in flash: I have deleted all files in flash - but I still get the same error message. According to the documentation there should be enough memory. Messages are pasted below.
What am I missing?
Torleif
Switch#dir
Directory of flash:/
No files in directory
15998976 bytes total (15997952 bytes free)
Switch#archive download-sw tftp://192.168.9.13/c3560-ipservicesk9-tar.122-55.SE.tar
Loading c3560-ipservicesk9-tar.122-55.SE.tar from 192.168.9.13 (via Vlan9): !!!!!!!
[OK - 15964160 bytes]
Loading c3560-ipservicesk9-tar.122-55.SE.tar from 192.168.9.13 (via Vlan9): !!!!!!!!
examining image...
extracting info (109 bytes)
extracting c3560-ipservicesk9-mz.122-55.SE/info (519 bytes)
System Type:             0x00000000
  Ios Image File Size:   0x00C19A00
  Total Image File Size: 0x00F37200
  Minimum Dram required: 0x08000000
  Image Suffix:          ipservicesk9-122-55.SE
  Image Directory:       c3560-ipservicesk9-mz.122-55.SE
  Image Name:            c3560-ipservicesk9-mz.122-55.SE.bin
  Image Feature:         IP|LAYER_3|PLUS|SSH|3DES|MIN_DRAM_MEG=128
Error: There is insufficient space in flash: to install the required
Error: image.  Clean up some old images, and try again.
Switch#
20 Replies 20
Thanks for the ratings.  Did it work?
12.2(50) was too big.
12.2.(46) installed fine.
Torleif
Ok.  Thanks.
Got another option for you ... If you don't NEED to use the HTML subdirectory you can just push the BIN file.  12.2(55)SE5 is approximately 12 Mb so it should fit.
Worked fine!
First time I tried I used the archive command - which of corse did not work with bin files. When I tried with copy tftp it worked fine!
Thank you!
Just to add my 2 cents. I believe the tar file you were trying to use for the upgrade needs 32mb of flash because it contains the IOS binary and the web based management files, you can use the the archive download-sw with the "imageonly" and "overwrite" options to archive the same result as the copy of the binary file alone.
archive download-sw /imageonly /overwrite source-url
Also at this time 12.2(55)SE6 is available for download, this version requires only 16MB of flash in most of the 3560 (non-E / non-X).
