improving EEM script to reset voice-ports in park state
br345678
I am looking to improve upon the EEM script I have written below to reset voice-ports that are in a parked state. As of now I have the following 2 applets written for each and every voice port on the router, 0/[0-3]/[0-3]:[0-23] .
I am not having much luck simplifying this down using nested loop statement and/or regex to loop through each voice port .
Would someone mind pointing me in the right direction. Thank you!
event manager applet PARK_MONITOR_0/0/0:0
description MONITOR HOOT PORT 0/0/0:0 FOR PARK STATUS
event timer watchdog time 300 maxrun 65
action 1.0 cli command "enable"
action 1.2 cli command "show voice call summ | include 0/0/0:0"
action 1.3 regexp "ONHOOK" "$_cli_result"
action 1.4 if $_regexp_result eq "1"
action 1.5 cli command "event manager run HOOT_RESET_0/0/0:0"
action 1.6 end
event manager applet HOOT_RESET_0/0/0:0
description AUTOMATED HOOT PORT 0/0/0:0 TOGGLE BITS FOR PARK_MONITOR_0/0/0:0
event none
action 1.1 cli command "config t"
action 1.2 cli command "voice-port 0/0/0:0"
action 1.3 cli command "define Rx-bits seize 0000"
action 1.4 cli command "define Rx-bits seize 1111"
action 1.5 cli command "exit"
action 1.6 syslog priority notifications msg "HOOT 0/0/0:0 has been reset by EEM" facility "EEM-FAC"
balaji.bandi
check below thread definish port range and checking each port and do the reset :
https://community.cisco.com/t5/network-management/eem-script-to-monitor-and-shut-no-shut-fxo-port/td-p/2057283
BB
The first EEM use watchdog the second one the even is none meaning it need to run  manually
MHM
