Initial Login for the Cisco Business Dashboard HyperV machine
KMNRuser
Forum,
We are trying to set up the Cisco Business Dashboard HyperV image and are at the initial login screen.  I have not been successful in trying to find what the initial login credentials are.  Can anyone provide the initial login for this?
 - I suggest you get some knowledge and get acquainted from here :
              https://www.cisco.com/c/en/us/support/cloud-systems-management/business-dashboard/products-installation-guides-list.html
 M.
5 Replies 5
marce1000
 - Try cisco
 M.
Thanks for the response.  that actually worked.
I am now at Command line in the Ubuntu shell and have no idea what to do next to launch Cisco Business Dashboard.  Any suggestions would be welcome!
 M.
The link you sent was very helpful and informative.  I am now able to browse to the Cisco Business Dashboard at an IP assigned by my DHCP server and can view the Dashboard.
The documentation that you so kindly provided also discusses "Performing Initial Setup for the Probe.  I had read that the HyperV machione image that we are demoing has the probe in it as well.
It goes on to discuss that the proble should also obtain an address via DHCP.  Unfortunately when i am looking on the DHCP scope for that subnet, i see the leased address for the Dashboard, but it does not appear that the proble has requested an address or that there is one leased to it..
Once again any recommendations would be greatly appreicated.  I want to discover my Cisco 9300 switches on my network and have them in the Dashboard.
Could I trouble you for the username an password you used .. ive tried cisco:cisco and CBD:cisco ... no luck
Thanks Paul
