Integrate WCS in iFrame Portlets
robertamg
I tried to setup an Iframe portlet to view the WCS status page. But all it shows is the login page of WCS, because it goes full screen after saving the portlet settings.
I configured all the hidden variables I saw.
So what did I do wrong? Any idea…
running: LMS 3.2 all latest updates are installed
B.Smeets
I experienced the same. Seems WCS is one of those applications that are not compatible with iFrames, it always pops up in its own window.
If the WCS page is corrupted in iFrames, simply put a link to WCS under Frequently Used Links.
Either way, you may use an URL like https:///webacs/networkSummaryAction.do to go directly to the WCS page you want.
thanks for your reply, but since Cisco is pointing out
they integrated WCS in LMS trough iFrame for Cisco Live there must be a way (http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/case_study_c36-565461_ps2425_Products_Case_Study.html)
Hope anyone knows?
Until than i'll use the link as advised
