LMS 3.2 Data Collection Issue
sumee
Hi ,
I have LMS 3.2 and license for adding 5000 devices , my data collection is running continously for the past 2 days, when i try to stop the daemon manager and restart it comes to idle state but after some time it again goes to Running state
I am not getting the best practices deviations and discrepaqncies report after this issue
I am attaching the ANIServer.properties , ani.log and ANIServer.log file
Please help
AFROJ AHMAD
Hi ,
You are hitting this bug , please contact TAC to get the Patch :
CSCtd49439    Data Collection never completes, and UT acquisition cannot run
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
this seems to be BugID CSCtd49439:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCtd49439
also consider to install the patch for BugID CSCtg20882:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?caller=pluginredirector&method=fetchBugDetails&bugId=CSCtg20882
if you have CM 5.2 you should consider to upgrade to CM 5.2.1 which is available here:
http://www.cisco.com/cisco/software/type.html?mdfid=282641773&flowid=5141&softwareid=280775108
the patches for BugIDs CSCtd49439 and CSCtg20882 are availabel by contacting TAC
