Inter Vlan Firepower
Cconchap
I am working with Firepower equipment and I need to establish communication between the vlans, can someone tell me how I can achieve it?
The vlans are created on the Firepower.
balaji.bandi
Firepower work in Zone-based - if that VLAN belongs to the same Zone you can configure ACP rule for the same souce vlan ip range and destination ip rance (vice versa )
here is for reference :
https://www.cisco.com/c/en/us/support/docs/security/firepower-ngfw/200908-configuring-firepower-threat-defense-int.html#anc16
BB
Thank you,
I tried the command in the documentation on the firewall to validate the policies and they work on the firewall, but not from the PCs I don't go through the firewall.
I think I have a communication problem between the switch and the firewall.
I currently have a route from the switch to the firewall 0.0.0.0 0.0.0.0 10.187.132.227
Is that okay or should I do it another way?
Because currently only those that are directly connected respond.
