IOS for 3640 router
krybabie
I am looking to buy a 3640 router with 32 megs flash and 128 megs ram.
I am looking for a software release that can do the following:
Traffic shaping and netflows. On my 2610 that was the SPservices 12.3(6)a
this is the filename:
c2600-spservicesk9-mz.123-6a.bin
I need the same on my new 3640 that i want to buy just need the correct image for it.
Malcolm
spremkumar
Level 9
Level 9
hi
this link (s/w advisory tool) may help u out ..
http://tools.cisco.com/Support/Fusion/FusionHome.do
regds
My CCO account does not let me login to the site
Hmmm
Malcolm
Hi malcolm,
if you need only the netflow and CAR support, you can opt for :
c3640-is-mz.12.3-4.XD3 or
c3640-is-mz.12.3-11.T2
both these images require 32/96 hardware.. hope this helps...
Raj
