ip access-group doesn't work on C1000-8P-2G-L
josue-espogeira
I have a C1000-8P-2G-L switch running 15.2(7)E11 C1000-UNIVERSALK9-M version and I am trying to add the below access-list into a vlan interface 597.
ip access-list extended GUEST-SVI-IN
deny ip any any
ip access-list extended GUEST-SVI-OUT
permit tcp any eq www any
deny ip any any
And when I try to add it into the interface Vlan597 I get the below output:
sw_reserva(config)#interface Vlan597
sw_reserva(config-if)#ip access-group GUEST-SVI-IN in
% Invalid input detected at '^' marker.
sw_reserva(config-if)#ip access-group GUEST-SVI-OUT out
It doesn't accept the command, how its possible to add an ACL into a SVI in C1000?
Thanks.
@josue-espogeira
 This is due platform limitation. If you check the datasheet, you can see
"●      Port-based ACLs for Layer 2 interfaces to allow security policies to be applied on individual switch ports."
Similar discussion here
https://community.cisco.com/t5/switching/catalyst-1000-x-series-switch-ip-access-group-command-missing/td-p/4627348
@josue-espogeira
