ip flow-cache timeout active 2
bsciarra1
Level 2
Level 2
Good afternoon.  On my 1841 when i enter the "ip flow-cache timeout active 2" command it accepts this command with no errors.  But when i look at my running-config this does not list.
I did the same thing on my 2811's and 3745 and it shows up in the running-config.
Should I assume if it doesnt' show up in my config file than it is not applied?
How can I verify that it is or isn't?
Thanks...
Don Jacob
Level 7
Level 7
Use the show commands "sh ip cache flow" and "sh ip flow export" to verify the NetFlow configurations. If the output of show command shows the active flow timeout to be 2, it has been applied.
Don Thomas Jacob
ManageEngine NetFlow Analyzer
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
