ip helper-address not available in SG220-50P
abey2887
I have an SG220-50P switch upgraded to the latest firmware (1.2.0.3) and the ip helper-address is not yet available to be used.
based on the release notes for this model of switches, the DHCP relay should be available.
Am I missing anything?
It doesn't look like ip dhcp relay as a valid available command
i was in the impression it was SG3XX, but looks like SG2XX has limited features.
look at the below admin guide :
https://www.cisco.com/c/en/us/support/switches/sg220-50p-50-port-gigabit-poe-smart-plus-switch/model.html#Configuration
BB
Thank you but based on the latest release notes, dhcp relay is available.
