01-10-2019 08:44 AM
Hi All,
i am asking my self how IP-helper work?
how IP helper differentiate between services?
for example, when a packet of DHCP request riching the helper, base on which packet`s field the helper deciding that this packet is DHCP? (base on ports/UDP, Payload or Layer 2 B.C etc.)
Oron Yaniv
Solved! Go to Solution.
01-10-2019 08:58 AM
Hi @Oron Yaniv,
The DHCP discover packets are identified by the port number associated with the DHCP service (UDP: source port = 68; destination port = 67).
These packets are sent with the broadcast destination address, but if a DHCP server is not found in the local network, the ip helper-address command changes the destination ip broadcast by a unicast destination ip (the one you indicate after the command ).
With this, it is possible for the packet to reach a DHCP server outside the broadcast domain.
01-10-2019 08:58 AM
Hi @Oron Yaniv,
