IP Phones with DHCP Server in Packet Tracer ?
huud
I'm configuring this network with IP Phones (I have NOT done IP Phones before) in Packet Tracer 6.2, I have already done enough research on it without any result, the videos that I see have connected PC to Phone and then Phone to Switch and segregated VLANS and configured DHCP pools in the router, I'm using DHCP server rather than the router, unsure if its possible like that.
So far what ever I have done of IP Phones is through videos but I'm running into issues.
The phones won't ring each other, I only see Configuring CM List.
My set up is such that I have IP phones separate from PCs.
When I tried to manually enter MAC address then too it would still show Configuring CM List in the GUI window of phone.
Scratching my head over what needs be done to make them ring each other.
Router Config:
Building configuration...
Current configuration : 1748 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname FF_Core_RTR
ip cef
no ipv6 cef
spanning-tree mode pvst
interface Loopback0
description Loopback interface to simulate internet connection
ip address 10.11.0.1 255.0.0.0
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.51
description Subinterface for HR VLAN
encapsulation dot1Q 51
ip address 193.179.12.1 255.255.255.192
ip helper-address 193.179.11.66
interface FastEthernet0/0.61
description Subinterface for IT VLAN
encapsulation dot1Q 61
ip address 193.179.12.65 255.255.255.192
interface FastEthernet0/0.71
description Subinterface for Sales And Marketing VLAN
encapsulation dot1Q 71
ip address 193.179.12.129 255.255.255.192
interface FastEthernet0/0.81
encapsulation dot1Q 81
ip address 193.179.12.193 255.255.255.192
interface FastEthernet0/0.251
description Subinterface for Network Management VLAN
encapsulation dot1Q 251
ip address 193.179.11.65 255.255.255.192
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
ip classless
ip route 193.179.12.0 255.255.255.192 FastEthernet0/0.251
ip route 193.179.11.64 255.255.255.192 FastEthernet0/0.51
ip flow-export version 9
telephony-service
max-ephones 15
max-dn 15
ip source-address 193.179.11.65 port 2000
ephone 1
device-security-mode none
line con 0
line aux 0
line vty 0 4
login
Deepak Kumar
Attach your lab here.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Please find the lab attached.
Thank You
DHCP option 150 is compulsory for Cisco VOIP services and you are missing the same. So Your IP Phones are not getting an IP address from the DHCP Server.
An Example for DHCP Services configuration for IP-Phones :
RouterA(config)#ip dhcp pool VOICE
RouterA(dhcp-config)#network 192.168.10.0 255.255.255.0
RouterA(dhcp-config)#default-router 192.168.10.1
RouterA(dhcp-config)#option 150 ip 192.168.10.1 #Mandatory for voip configuration.
Reconfigure a DHCP service for the Phones.
Deepak Kumar
Deepak Kumar,
Thanks, from your reply I understand, its not possible to have phones ring each other without DHCP set up  on router.
Much appreciated your clarification.
Thank You
