10-25-2018 01:38 PM
Hi all,
I am looking for the MIB objects and OIDs for the snmp trap monitoring to the device below.
・Catalyst3850 Version IOS-XE 16.3.5b
I checked the MIB objects and OIDs at the following site.
<MIB Locator>
http://mibs.cloudapps.cisco.com/ITDIT/MIBS/servlet/index
Please tell me whether the MIB is correct that gets voltage, FAN or temperature abnormality trap.
・MIB:CISCO-ENMMON-MIB
- ciscoEnvMONVoltageState
- ciscoEnvMONTemperatureState
- ciscoEnvFANState
Please tell me whether the MIB is correct that gets the trap when the device shutdow.
- ciscoEnvEnableshutdownNotification
Thanks in advance.
10-26-2018 02:20 AM
- In general you will only be able to test the operational status of the MIBS by using some snmp manager software, loading the MIBS, and querying variables which you intend to use.
M.
10-27-2018 10:10 PM
You're right.
I will verify it in cooperation with the snmp manager software.
Thank you for your reply.
