IP SLA Documentation
andrewdours
Cisco Community,
I've not been able to find detailed documentation on IP SLA.  "Detailed".  I've found plenty of documentation, but many of the details are lacking.  I want to understand what the thresholds are for a specific SLA and how to take action on the threshold.  As an example, I'd like to use icmp-jitter to test the following:
1. Latency take action if over 50ms
2. Jitter take action if over 50ms
3. Packet Loss take action if 10% packet loss
There are plenty of articles that show how to get the IP SLA started and I'm able to do that.  I just don't have the details regarding thresholds or "triggers" that I can use in an EEM script.  I plan to set the "trouble" interface to passive in the EIGRP process using an EEM script.
Thanks in advance,
Andrew
balaji.bandi
Are you looking to make action based on each condition or meet all conditions :
not sure whta device - you get example :
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipsla/configuration/15-mt/sla-15-mt-book/sla_udp_jitter.html
BB
BB,
If any one of the 3 conditions exist, then I was planning to set the interface passive using EEM script.
Andrew
You you use
AND – it requires that all the objects defined in the track list to be up.
OR – it requires that at least one object to be up.
make 3 IP sla
ip sla 1
xxxxxx
ip sla 2
xxxxxx
ip sla 3
xxxxx
track X list boolean and   or OR ( depends on the requirement)
object 1
object 2
object 2
BB
