IR809 - Upgrade
Niklas.D
So i am trying to upgrade a IR809 - firmware Version 15.7(3)M2 - and going to  ir800-universalk9-bundle.SPA.159-3.M1.bin
I get a timeout
bundle install flash:ir800-universalk9-bundle.SPA.159-3.M1.bin
Installing bundle image: /ir800-universalk9-bundle.SPA.159-3.M1.bin.......................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
The semaphore timeout period has expired.
anyone seen this problem before?
Niklas.D
Hi Yes i made a TAC case out of it.
And you will need to make a on preem installation.
You need to extract the files from "ir800-universalk9-bundle.SPA.159-3.M4.bin"  so you get this
ir800-hv.srp.SPA.3.1.21
ir800-ref-gos.img.1.14.0.6
ir800-universalk9-mz.SPA.159-3.M4
MANIFEST
Upload them to the router.
Then change the boot
conf t
no boot system
boot system flash:/ir800-universalk9-mz.SPA.159-3.M4
boot system flash:/ir800-universalk9-mz.SPA.157-3.M2
After this you need access with console
reboot it and break it accessing rommon-1 ,crtl + c to break at boot up.
then boot with the new file
boot flash:ir800-hv.srp.SPA.3.1.21
(this will not install the new firmware)
This will boot in to the new firmware, when booted in preform a install of the new firmware:
bundle install flash:ir800-universalk9-bundle.SPA.159-3.M4.bin
After the reload check if was a succes with
sh platform nvram
Environ setting
-------------------------- TABLE -------------------
LICENSE_SERIAL_NUMBER=FCW223300HA
LICENSE_PRODUCT_ID=IR809G-LTE-GA-K9
CONFIG_REG=0x102
BOOT=flash:/ir800-universalk9-mz.SPA.159-3.M4,12;flash:/ir800-universalk9-mz.SPA.157-3.M2,12; <<
LICENSE_BOOT_LEVEL=
RET_2_RTS=11:36:56 CET Wed Dec 22 2021
SB_CORE_VER=F01047R15.017cc1eea2019-02-08
SB_ML_VER=MA0061R06.0404022015
17 Replies 17
Mark Elsen
 - Reboot the device (of course with the existing version) and try again.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
n/a
 - Confused about this reply,
  M.
       Beauty and terror
      Just keep going
       No feeling is final
MOVA4GRV15 uptime is 57 minutes
MOVA4GRV15#bundle install flash:ir800-universalk9-bundle.SPA.159-3.M1.bin
Installing bundle image: /ir800-universalk9-bundle.SPA.159-3.M1.bin........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Timeout!
MOVA4GRV15#
MOVA4GRV15#
 - Check available space in the flash:
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Morning Marce
MOVA4GRV15#dir
Directory of flash:/
12 -rw- 64350862 Jul 8 2018 07:58:16 +01:00 ir800-universalk9-mz.SPA.157-3.M2
28 -rw- 192108099 Mar 20 2020 10:59:54 +00:00 ir800-universalk9-bundle.SPA.159-3.M1.bin
994918400 bytes total (668237824 bytes free)
Should be fine?
 - The bundle is rather big , could you remove it from the flash and run the install command , using the bundle from a tftp source ? Also check the logs after the timeout error  with show logging. Perhaps there might be additional info.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
*Mar 24 11:34:06.099: %LINK-3-UPDOWN: Interface GigabitEthernet2, changed state to up
*Mar 24 11:34:06.101: %LINK-3-UPDOWN: Interface GigabitEthernet1, changed state to down
*Mar 24 11:34:06.101: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Mar 24 11:34:08.865: %IR800_BIOS-2-IR800_BIOS_UPGRADE_REQUIRED: Running version: 25, available version: 18
*Mar 24 11:35:05.187: %IR800_BIOS-2-IR800_BIOS_UPGRADE_FAIL: BIOS upgrade error detected, rc=3
*Mar 24 11:35:05.187: %IR800_BIOS-2-IR800_BIOS_UPGRADE_FAIL: BIOS upgrade failed, retrying...
*Mar 24 11:36:01.373: %IR800_BIOS-2-IR800_BIOS_UPGRADE_FAIL: BIOS upgrade error detected, rc=3
*Mar 24 11:36:01.381: %IR800_BIOS-2-IR800_BIOS_UPGRADE_FAIL: BIOS upgrade error: (3 - No such process) upgrading BIOS memory
*Mar 24 11:36:01.381: %IR800_FPGA-2-UPGRADE_REQUIRED: FPGA upgrade is in progress. Current version = 2.A.0, new version = 2.7.0. System will upgrade now and then reboot automatically.
*Mar 24 11:36:05.985: %IR800_FPGA-2-SPI_UPGRADE_FAIL: FPGA upgrade operation failed : PROM verify, SPI error code 1
*Mar 24 11:39:44: %LINK-3-UPDOWN: Interface Async1, changed state to up
*Mar 24 11:39:44: %LINK-3-UPDOWN: Interface Async0, changed state to up
*Mar 24 11:39:45: %SYS-3-HARIKARI: Process IR800 Test top-level routine exited
*Mar 24 11:41:20: %CELLULAR-2-MODEM_UP: Cellular0 modem is now UP.
*Mar 24 11:42:20: %CELLWAN-2-MODEM_RADIO: Cellular0 Modem radio has been turned on
*Mar 24 11:42:30: %CELLWAN-2-BEARER_UP: Instance id=0, Default bearer (bearer_id=5) in Cellular0 is now UP
*Mar 24 11:42:32: %LINK-3-UPDOWN: Interface Cellular0, changed state to up
There are no bundel install tftp/ftp command
MOVA4GRV15#bundle install ?
flash: Bundle image name. Format is device:image_name
 - I found a bug reference to this , but it is unclear how this related to your current upgrading sequence , one thing you could still verify is the version of the boot-loader/bios and upgrade it first if at all applicable. Check release notes of the intended software version which you were trying to install. If that leads to nothing you will need to contact Cisco  TAC about this and forward the errors which you showed here (the output of show logging)
                https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg00547/?rfs=iqvred
M.
       Beauty and terror
      Just keep going
       No feeling is final
 -                  Referring back to the mentioned bug report :
   The fix will be available in the upcoming 15.6(3)M4 (end of January 2018) and the 15.7(3)M1 (end of November 2017) releases
  - One possibility would be try to install  one of the versions mentioned above first as an intermediate step.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
I tried same outcome, timeout at the end. Tomorrow when i am back in office i will try to boot the firmware from rommon.
Niklas.D
This is still a Issue for me anyone resolved it?
I have this same problem, .........................Timeout!
Rebooting doesn't help.
