01-23-2014 01:16 AM
hello, can we install Cisco Prime Infrastructure 1.2 or 2.0 on UCS C22, C220M3 or NCS Hardware Appliance without using VMware ?
thanks.
Solved! Go to Solution.
01-23-2014 04:33 AM
Unfortunately, this isn't yet supported for Prime Infrastructure.
you have Installed VMWare first.
Thanks-
Afroz
[Do rate the useful post]
01-23-2014 05:30 AM
Hardaware does not come with VMware. you need to installed VM on top of it.
Thanks-
Afroz
01-23-2014 04:33 AM
Thanks-
Afroz
01-23-2014 05:24 AM
hi, what about the NCS hardware appliance, does it come with VMware because in the configuration tool i don't see the VMware license but i can check Cisco Prime 2.0 ! .
thanks.
01-23-2014 05:30 AM
Thanks-
Afroz
01-23-2014 05:47 AM
thanks a lot.
