Is there a way to poll a given running config setting from my switches with PI ?
JohnW63
I would like to query all of our switches to see if a setting in saved correctly and I hoped PI would be able to do it. For instance if I want to insure that all the enable secret lines are the same. Can PI do this or is there some sort of scripting language way to query all my running configs ?  They are 9300s, 3650s, 2960s, 3560s, and 3700s.
balaji.bandi
Prime can do for you
https://www.cisco.com/c/dam/en_us/training-events/product-training/prime-infrastructure-31/ja-audit/PI31_Audit_JobAid.pdf
you can also do out of the box scripting using ssh to audit the same and make your own report.
BB
