Is VSS supported in Cisco Prime Infrastructure 1.2?
srosenbe
Martin Ermel
VSS support (converting standalone switches into a VSS)  was introduced with LMS 3.0.1 if I remember well and it is still there in LMS 4.2 (Cisco Prime Infrastructure):
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.1/user/guide/configuration/configvss.html
Config Mgmt is supported, also.
