ISE compatibilty with extreme switches
newtamil2011
Hi Experts,
Users are unable to get authenticate when they connecte in extreme switches because of the below error
11051 RADIUS packet contains invalid state attribute.
For cisco switches it is working fine without any issues.
Whether ISE supports 802.1x authentication for extreme switches ?
Tamil
marce1000
- Check :
   http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/compatibility/ise_sdt.html#pgfId-55038
That being said , it behavior may also depend on the current ISE version being used.
M.
