ISR 4321 EN console indicators
yoav-shneor
Cisco 4321  EN led next to console is flashing rapidly .
Cisco is not responfding to WAN / LAN / console .
On cisoc documents the EN led Indicates SFP port status .
On chat GPT "EN" or "Ethernet" LED s are associated with the Ethernet interfaces.
Any Idea sombody ?
yoav-shneor
Hi All ..
After replacing power supply it took a minute and the LED stopped.
Probably the power supply was damaged and did not supply the exact  12V 9 Ampere needed.
TNX all
5 Replies 5
marce1000
 - FYIhttps://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/Overview.html#80850
   - I would also advise that you cold boot (from power cycle) the system with first a console attached and scrutinize the boot process (look for errors), for instance,
 M.
TNX ,
Already lookd int that document.
I don't use any SFP so "SFP EN" led is erelevent .
Also the LED is directly under the blue line for the console so i tought it is more related to a serial port problem of any sourt.
There is another one left to the console.
          - Is the device reachable on the network ?
 M.
DanielP211
Hello!
If console dosent output no info on console(assuming you have the correct speed) the device is probably broken. Have you tried rebooting it? Does it display anything then?
BR
****Kindly rate all useful posts*****
yoav-shneor
Hi All ..
TNX all
