Issue related IP flow monitor command in Netflow
TechBhole241
I have configured Net-flow related commands in my network switch which belongs to Catalyst 9500. when I am configuring Ip flow monitor command under any trunk port, I am facing an error which is mentioned below:
Switch(config)#int Te1/1/1
Switch(config-if)#ip flow monitor NTA-flow-monitor output
% Flow Monitor: Failed to add monitor to interface: Unsupported non-key field "interface output" for ip traffic in Output direction
Switch(config)# int gi1/0/24
Switch(config-if)#ip flow monitor NTA-flow-monitor input
% Flow Monitor: Failed to add monitor to interface: Unsupported non-key field "interface input" for ip traffic in Input direction
Kindly help me anybody by giving appropriate solution.
Thanks in advance
Mohan Singh
marce1000
  - Checkout this thread : https://community.cisco.com/t5/network-management/flexible-netflow-configuration/td-p/3959538
 M.
