04-24-2022 09:49 PM
when i run the show mac address-table it doesn't show the address option and | for the output modifier. why?
when i give the command it displays this below;
AZ-SWO1#show mac address-table
Mac Address Table
Vlan Mac Address Type Ports
1 0040.0b72.5c01 DYNAMIC Gig1/0/2
1 0060.70b0.dc02 DYNAMIC Gig1/0/1
1 00d0.d39b.8a03 DYNAMIC Gig1/0/3
1 00d0.d39b.8a04 DYNAMIC Gig1/0/4
but when i issue this command below, it gives an invalid input;
AZ-SWO1#show mac address-table 0040.0b72.5c01
% Invalid input detected at '^' marker.
then trying to check the options i have here is what i get
you can see both the address(to locate a specific mac address) and the pip(for modefier) is not there
AZ-SWO1#show mac address-table ?
dynamic dynamic entry type
interface List MAC adresses on a specific interface
static static entry type
<cr>
please what could be the reason for the invalid input ant the asbsence of the address and the pip?
04-24-2022 10:24 PM
HI,
What is the model of switch and software version running on that switch?
John
04-25-2022 01:46 AM
device model is 3650-24ps
04-25-2022 12:00 AM
The latest code do support that command :
#show mac address-table address ( H.H.H 48 bit mac address)
what model of the device, and IOS code running
another way to get only specific
#show mac address-table | in 0040.0b72.5c01
04-25-2022 01:58 AM
the invalid input marker sign ^ also appears under the | (pip) as well as under the address.
Or could it be because i am learning with packet tracer
04-25-2022 01:06 AM
I have a hunch that you are doing this in Packet Tracer ? PT is not a 'real' switch, but rather a simulator with just a limited amount of commands available compared to what you what see in a full IOS switch.
In Packet Tracer, you get this (identical to your output):
Switch#sh mac address-table ?
interfaces interface entry type
A full IOS switch would give you something like this:
address Address to lookup in the table
aging-time MAC address table aging parameters
count Number of MAC addresses in the table
dynamic List dynamic MAC addresses
multicast List multicast MAC addresses
secure List secure MAC addresses
static List static MAC addresses
vlan List MAC addresses on a specific vlan
| Output modifiers
04-25-2022 01:49 AM
yes
you are very correct
But is there no way out?
Or should i just continue?
04-25-2022 01:51 AM
with Packet Tracer, you have no other options than those you see. What specific task are you working on ?
04-26-2022 02:04 AM
okay.
i am taking some tutorials from CBT nuggets. So, as part of excersices, i'm working on how to locate devices on a switch network.
if you can give me any further guidiance i will appreciate
thanks
