Issues in CWLMS-4.0
ikbalc
After installing the New Cisco LMS (Version 4.0) I am facing the following problems that need to be resolved.
1.Leased line connectivity from Central router to remote locations are showing as cloud.In earlier version this is not showing.
2.How to generate the syslog output in LMS 4.0.I have followed the below link and configured to enable syslog but syslog is not getting generated.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/Reports/fault_even_reports.html#wp1265904
3.LMS is very slow
Ikbal C
Nael Mohammad
Level 5
Level 5
For the first issue, can you post a screenshot and the device type show ver in question and where you are encountering the problem in LMS. For the second issue follow the troubleshooting steps in LMS with the following link.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/monitoring_troubleshooting/mntfaq.html#wp1083500
And post the "pdshow" output along with the CSCOpx/log Syslog related files so we can debug the issue.
