Java exceptions during restorebackup.pl
yjdabear
This is from restoring a copy of the LMS 2.2 daily db backup into a fresh install of LMS 2.6.
tail restorebackup.log
[Tue Sep 26 16:43:58 2006] getNextJobId() - next job id returned is 1072
[Tue Sep 26 16:43:58 2006] Registering ChangeAuditDefaultPurge with job id 1072.
[Tue Sep 26 16:43:58 2006] Warning - No current logger set
[Tue Sep 26 16:43:58 2006] getNextJobId() - next job id returned is 1073
[Tue Sep 26 16:43:58 2006] Registering SysInvCollection with job id 1073...
[Tue Sep 26 16:43:58 2006] getNextJobId() - next job id returned is 1074
[Tue Sep 26 16:43:58 2006] Registering SysInvPoller with job id 1074...
[Tue Sep 26 16:43:58 2006] JobRegistrationUtil : Completed successfully.
[Tue Sep 26 16:43:58 2006] INFO: Calling JobRegistration Utility........
[Tue Sep 26 16:43:58 2006] INFO: executing /opt/CSCOpx/bin/cwjava -cw /opt/CSCOp
x -cw:jre lib/jre -cp:p MDC/tomcat/webapps/rme/WEB-INF/classes:MDC/tomcat/shared
/lib/MICE.jar:MDC/tomcat/webapps/rme/WEB-INF/lib/log4j.jar:MDC/tomcat/webapps/rm
e/WEB-INF/lib/xdi.jar:MDC/tomcat/shared/lib/NATIVE.jar com.cisco.nm.rmeng.common
.jobregistration.JobRegistrationUtil /opt/CSCOpx/MDC/tomcat/webapps/rme/WEB-INF/
classes/com/cisco/nm/rmeng/common/jobregistration/jobregistration.dat
[Tue Sep 26 16:43:58 2006] Migration of the RME Data is in progress...
[Tue Sep 26 16:43:58 2006] See the log file /var/adm/CSCOpx/log/migration.log
for progress..
Exception in thread "main" java.lang.NullPointerException
at java.io.Writer.write(Writer.java:126)
at org.apache.log4j.helpers.QuietWriter.write(QuietWriter.java:39)
at org.apache.log4j.WriterAppender.subAppend(WriterAppender.java:302)
at org.apache.log4j.WriterAppender.append(WriterAppender.java:157)
at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:251)
at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders
(AppenderAttachableImpl.java:57)
at org.apache.log4j.Category.callAppenders(Category.java:255)
at org.apache.log4j.Category.forcedLog(Category.java:445)
at org.apache.log4j.Category.fatal(Category.java:436)
at com.cisco.nm.rmeng.migration.MigrMain.main(Unknown Source)
tail /var/adm/CSCOpx/log/migration.log
26/Sep/2006 17:02:55:304 1133199 [main] INFO com.cisco.nm.rmeng.migration.MigrMain 673 - Startup and VLAN configurations available in following directory /media/tempBackupData/rme/var/adm/CSCOpx/files/archive/config
26/Sep/2006 17:02:55:315 1133210 [main] ERROR com.cisco.nm.rmeng.migration.MigrMain 187 -
Directory /media/tempBackupData/rme/var/adm/CSCOpx/files/archive/config is not available
at com.cisco.nm.rmeng.migration.DcmaDataMigrator.restoreOtherArchive(DcmaDataMigrator.java:677)
at com.cisco.nm.rmeng.migration.DcmaDataMigrator.doMigration(DcmaDataMigrator.java:183)
at com.cisco.nm.rmeng.migration.MigrMain.callAppDoMigration(Unknown Source)
26/Sep/2006 17:02:55:317 1133212 [main] FATAL com.cisco.nm.rmeng.migration.MigrMain ? - Operation could not be proceeded..
26/Sep/2006 17:02:55:318 1133213 [main] FATAL com.cisco.nm.rmeng.migration.MigrMain ? - Reason is :null
26/Sep/2006 17:02:55:391 1133286 [main] DEBUG com.cisco.nm.rmeng.migration.MigrMain ? - Successfully enabled DM auto manage
I found only a "Logs" directory in /media/tempBackupData/rme/var/, no "files". Does this mean the restore did not succeed? For instance, there's no NetConfig jobs found.
7 Replies 7
yjdabear
The restore command used:
/opt/CSCOpx/bin/perl /opt/CSCOpx/bin/restorebackup.pl -d /var/temp/477 -t /media
The temp directory directive (-t) seems mandatory, which essentially triples the disk space requirement for a restore from >6GB to >18GB.
Here's the comparison of /var/temp/477/rme (direct copy of LMS 2.2 backup) and /media/tempBackupData/rme/ (temp directory used by restorebackup.pl):
ls -al /var/temp/477/rme
total 9613492
drwxr-xr-x 9 root other 512 Sep 26 14:05 .
drwxr-xr-x 4 root other 512 Sep 26 13:58 ..
drwxr-xr-x 2 root other 512 Sep 26 14:05 cas
drwxr-xr-x 2 root other 512 Sep 26 14:05 cjm
drwxr-xr-x 2 root other 512 Sep 26 14:05 config
drwxr-xr-x 2 root other 512 Sep 26 14:07 database
-rw-r--r-- 1 root other 4919680000 Sep 26 14:05 filebackup.tar
drwxr-xr-x 2 root other 512 Sep 26 14:07 inventory
drwxr-xr-x 2 root other 512 Sep 26 14:07 netconfig
-rw-r--r-- 1 root other 438 Sep 26 14:05 rme.tmpl
drwxr-xr-x 2 root other 512 Sep 26 14:07 swim
ls -al /media/tempBackupData/rme/
total 9613496
drwxr-xr-x 11 root other 512 Sep 26 16:12 .
drwxr-xr-x 4 root other 512 Sep 26 16:13 ..
drwxr-xr-x 3 casuser casusers 512 Sep 26 15:24 product
drwxr-xr-x 3 casuser casusers 512 Sep 26 15:22 var
du -sk /var/temp/477/rme
6262345 /var/temp/477/rme
du -sk /media/tempBackupData/rme
11191889 /media/tempBackupData/rme
Where did restorebackup.pl get /var from? On the LMS 2.2 box, /var/adm is a softlink to /var/Logs/CSCO/adm/CSCOpx. Is this what confused restorebackup.pl?
ls -al /var/adm
total 16180
drwxrwxr-x 9 root sys 512 Sep 27 10:00 .
drwxr-xr-x 39 root sys 1024 May 25 16:13 ..
lrwxrwxrwx 1 root other 25 Jul 12 2004 CSCOpx -> /var/Logs/CSCO/adm/CSCOpx
Yes, the symlink is most likely the problem here. We do not support a symlink for /var/adm/CSCOpx. We offer other ways of relocating large items like the config archive and the SWIM repository.
To try and fix this, you could fix the filebackup.tar manually, or fix the LMS 2.2 server, then take the backup again.
Well, the symlink thing is by design and out of my control. So I used this workaround while restoreback.pl was pausing for answer to one of its questions: mv /media/tempBackupData/rme/var/Logs/CSCO/adm /media/tempBackupData/rme/var/
The restore finished "successfully". But I'm finding /var/adm/CSCOpx/files is a lot smaller on the LMS 2.6 box than the 2.2 server, and has a very different directory structure. Is the size difference because I answered N to "Do you want to collect inventory [Y/N]:[N]"?
lms22-(/var/Logs/CSCO/adm/CSCOpx/files)->du -sk .
2735067 .
lms22-(/var/Logs/CSCO/adm/CSCOpx/files)->ls -al
total 8
drwxr-x--- 8 casuser casusers 1024 Feb 2 2006 .
drwxr-x--- 4 casuser casusers 96 Mar 27 2006 ..
drwxr-x--- 6 casuser casusers 96 Mar 19 2005 archive
drwxr-x--- 2 casuser casusers 1024 Sep 7 13:34 inventory
drwxr-xr-x 4 root other 96 Jul 12 2004 jobs
drwxr-x--- 2 casuser casusers 96 Sep 25 11:33 netconfig
drwx------ 82 casuser casusers 2048 May 25 11:23 schedule
drwxr-xr-x 5 casuser casusers 96 Jul 11 2002 sw_images
[lms26:/var/Logs/CSCO/adm/CSCOpx/files] # du -sk .
271221 .
[lms26:/var/Logs/CSCO/adm/CSCOpx/files] # ls -al
total 10
drwxrwx--- 5 casuser casusers 512 Sep 18 13:22 .
drwxr-x--- 4 casuser casusers 512 Sep 27 14:04 ..
drwxrwx--- 9 casuser casusers 512 Sep 28 10:30 .SQLAnywhere
drwxr-xr-x 15 casuser casusers 512 Sep 28 10:11 rme
drwxr-xr-x 4 casuser casusers 512 Sep 18 13:22 scripts
Here's the restore log:
Restore started at : 2006/09/27 16:10:53
Please see '/var/adm/CSCOpx/log/restorebackup.log' for status.
OS of the backup archive is..................... : Unix
Generation to be restored is ................... : .
Backup taken from............................... : /var/temp/477
Common Services version in the backup data is... : 2.2
Common Services is installed in................. : /opt/CSCOpx
The temp folder for this restore program........ : /media/tempBackupData
Applications installed on this machine ......... : [Common Services][Campus Manager][Resource Manager Essentials]
Applications in the backup archive ............. : [Common Services][Campus Manager][Resource Manager Essentials]
Applications to be restored are................. : [Common Services] [Campus Manager] [Resource Manager Essentials]
Available disk space in NMSROOT................. : 9157105 Kb
Available disk space in temp folder............. : 12175536 Kb
Required disk space in NMSROOT.................. : 6308433 Kb
Required disk space in temp..................... : 11112808 Kb
Copying the backup files to the temporary location [/media/tempBackupData]
INFO: Not able to unlink(/media/tempBackupData/rme/filebackup.tar)
preRestore of [Common Services] has started.
preRestore of [Common Services] has completed.
preRestore of [Campus Manager] has started.
preRestore of [Campus Manager] has completed.
preRestore of [Resource Manager Essentials] has started.
Not all data from RME 3.4.x and RME 3.5.x will be migrated to RME 4.0.x. For information on the data that is migrated, see the "Data Migration From an Earlier Version" section in the "Installing RME" chapter in the RME 4.0.x Installation Guide for details. Do you want to continue[Y/N]:[Y]
Do you want to migrate syslogs [Y/N]:[Y]
preRestore of [Resource Manager Essentials] has completed.
doRestore of [Common Services] has started.
License check started.
License check completed.
Restoring certificate.
Restored Certificate.
Restoring Common Services database.
Restoring CMIC data.
Restored CMIC data.
Restoring CMC data.
Restored CMC data.
Restoring Security Settings.
Restored Security Settings.
Restoring DCR data.
Restored DCR data.
Restoring Certificate key store.
Restored Certificate key store.
Restoring JAAS configuration.
Restored JAAS configuration.
doRestore of [Common Services] has completed.
doRestore of [Campus Manager] has started.
doRestore of [Campus Manager] has completed.
doRestore of [Resource Manager Essentials] has started.
See the log file /var/adm/CSCOpx/log/migration.log for progress..
doRestore of [Resource Manager Essentials] has completed.
postRestore of [Common Services] has started.
postRestore of [Common Services] has completed.
postRestore of [Campus Manager] has started.
postRestore of [Campus Manager] has completed.
postRestore of [Resource Manager Essentials] has started.
postRestore of [Resource Manager Essentials] has completed.
Restored successfully.
Hi yjdabear ,
I have the same problem
restore data from LMS2.2 to LMS 2.6
How did you resolve it?
can you post me at [email protected]
Thanks in advance
Leonardo
The directory layout will be very different under LMS >= 2.5. The reason for the size difference could be that job information is not restored across servers. While you will have ChangeAudit records, your job logs will no longer exist. The main thing to check is your config archive (under files/rme/dcma/devfiles) and the software repo (under rme/repository/swim).
Note: certain ChangeAudit data may not be migrated if the database entries could not be found. This is fine. Those non-migrated records could have been left over from a reinitialized database.
Hi Jclarke,
with same errors
in the directory that you suggest there ins't anything
The configuration files are absent
I have to restore data first in LMS 2.5.1 and then make an upgrade to LMS 2.6?
Thanks in advance
Leonardo
