09-19-2005 06:04 AM
I'm currently running lms2.5 with all the latest patches installed and am getting errors on the server itself -
Faulting application java.exe, version 0.0.0.0, faulting module kernel32.dll, version 5.2.3790.0 fault address 0x000017b1.
It looks like I get these while ut discovery initially starts, but discovery does finish. JRE 1.42_08 is installed on my machine...is that what it is supposed to be? Any ideas on the above error?
Thank you,
Michael Mendoza
09-22-2005 01:49 PM
try using JRE 1.4.2_06, check the following link for information on using JRE 1.4.2_06 :
09-28-2005 03:22 PM
I think there might be a patch you can add that brings in support for 1.4.2_08. You should not be running 1.4.2_06, there were several security problems recently announced in it. If you cannot find the support, I urge you to beat Cisco down until they produce one.
09-28-2005 05:38 PM
1.4.2_08 is supported on both LMS 2.2 (using a patch) and LMS 2.5 (by installing Common Services 3.0 Service Pack 2)
