LACP configuration - maximum bandwidth between PC workstations
What is maximum bandwidth between PC workstations assuming both switches are configured with default load sharing options for LACP protocol and additionally, RSTP protocol has been configured for both switches ? Is this configuration/connection correct at all ?
SW1# show etherchannel load-balance -> EtherChannel Load-Balancing Configuration: src-mac
SW2# show etherchannel load-balance -> EtherChannel Load-Balancing Configuration: src-mac
Leo Laohoo
You want theoretical answers or actual "in the wild" scenario?
Theoretical answer is 10 Gbps because the PC can only Tx or Rx at one speed.
since there are two port channels, one will be blocked. That is assuming that both links carry the same Vlans.
With 4 10GB links, full duplex, you will get 80GB max. But Leo is right: in reality, you will only get 10, because the PCs are the limiters.
Joseph W. Doherty
BTW, default load sharing varies per switch platform, although you show what's being used in this case, i.e. src-mac.
Besides the issue that the host interfaces are a bottleneck compared to the Etherchannel bandwidth (and one of those groups blocked by STP), between a pair of hosts (as correctly noted by @Leo Laohoo and @Georg Pauwen), for most LB algorithm choices, including  your src-mac, all traffic will be restricted to using only one Ethercannel link.  Further, even if you can use one of the "rarely" provided LB choices that use TCP/UDP port numbers, any one flow will always be restricted to just one Etherchannel link (this to insure a flow's packet delivery sequence isn't changed).
